TrailBlazer 2002-2009
Overheating Chevy
Old Feb 26, 2024 | 4:31 AM
Leihenseder's Avatar
Default Overheating Chevy
I have an 03 Chevy Trailblazer that started overheating so i replaced the radiator and thermostat thinking that should rectify the problem. Well it wasnt till then i noticed the leak under the passenger side wheel well. now the only thing that can leak in that area is the heater core, Am I correct? it still overheating but can go about 20 miles before it does. i guess my question is can a heater core make your vehicle over heat? I got to get this fixed asap and i dont know what to do...
Old Feb 26, 2024 | 7:37 AM
Welcome from Florida. When the heater core leaks it will leak inside the car on the passenger side. Look for a leak under the hood such as a hose even a freeze plug.
Old Feb 26, 2024 | 8:00 AM
low coolant can definitely make your car overheat. Be careful or you could destroy your engine.
Old Feb 26, 2024 | 11:33 PM
chem_man's Avatar
15 Year Member
Plug in a capable OBD II code reader/live data scanner and see what temperature is being reported to the PCM by the Engine Coolant Temperature (ECT) sensor. You could have a defective ECT sensor.
brenteric69
Jan 22, 2015 9:45 PM
Mommyrocket84
Nov 11, 2014 1:49 PM
Edwardsd1
10
Jul 22, 2012 3:33 PM
pmccrite
Jul 26, 2010 7:30 PM
FloydCollins
Nov 30, 2008 6:03 AM
