TrailBlazer 2002-2009
power steering leak at pump/pulley
Old Jan 29, 2012 | 8:51 PM
irnmikk ss's Avatar
New User
Awaiting E-mail Confirmation
Default power steering leak at pump/pulley
2006 trailblazer ss , 6.0l
While doing oil change I noticed an oil leak that is coming from what appears to be..behind the pulley on the power steering pump, , go figure my extended warranty just expired 2000kms ago.... is that just a seal behind the pulley that can be changed? it appears that the pulley is pressed on and the center is rounded so not sure how/if it unscrews? any info or links to diagrams would be appreciated, I've had my 06 SS since new and besides a pinion seal replaced (warranty) I've had no other problems, would rather attempt to repair myself if possible rather than bring to pirate dealer ..............very curious if any one else has had this same issue?? thx agn for any info , much appreciated
Old Jan 29, 2012 | 11:53 PM
nj85z28's Avatar
Senior Site Administrator
The pulley is pressed on and you need a special tool set to remove it. Are you sure its not a leaky hose?
Got this from the autozone website, hope it helps
http://www.autozone.com/autozone/rep...96b43f80cb13f4
5.3L & 6.0L Engines
  1. Remove the drive belt.
  2. Remove the PCM from PCM mounting bracket and move to the side.
  3. Remove the power steering pressure hose from power steering pump.
  4. Remove the power steering pump return hose from power steering pump.
    Fig. Remove the power steering pressure hose (1) and return hose (3) from power steering pump (2)
  5. Remove the power steering pump mounting bolts.
  6. Remove the power steering pump.
  7. Remove the power steering pump pulley, as follows:
    1. Secure the power steering pump in a vise, taking care not to damage the power steering reservoir.
    2. Using Power Steering Pump Pulley Removal Tool J 25034-C, or equivalent, remove the power steering pump pulley.
  8. If applicable, remove the power steering pump reservoir.
To install:
  1. If applicable, install the power steering pump reservoir.
  2. Install the power steering pump pulley, as follows:
    1. Install the power steering pump pulley to the end of the power steering pump shaft.
    2. Install the power steering pump pulley to the power steering pump using Power Steering Pump Pulley Installer tool no. J 25033-C, or equivalent.
    3. Install the power steering pump pulley (1) flush against the end of the power steering pump shaft (2), with an allowable variance of 0.010 in. (0.25mm).
      Fig. Install the power steering pump pulley (1) flush against the end of the power steering pump shaft (2), with an allowable variance of 0.010 in. (0.25mm)
  3. Align the power steering pump with mounting bolt holes on engine block.
  4. Install the power steering pump mounting bolts. Tighten the bolts to 18 ft. lbs. (25 Nm).
  5. Attach the power steering pump return hose to power steering pump.
  6. Attach the power steering pump pressure hose to power steering pump.
  7. Tighten the fittings to 18 ft. lbs. (25 Nm).
  8. Install the PCM to PCM mounting bracket.
  9. Install the drive belt.
  10. Bleed the power steering system.
ednarg
Oct 17, 2013 8:49 AM
brylamca
Jul 24, 2009 1:03 PM
bgpunk2001
May 20, 2008 10:53 AM
osiris204850
Nov 1, 2006 9:42 PM
