TrailBlazer 2002-2009
Rear HVAC not working
Old May 10, 2015 | 3:32 PM
Malachi's Avatar
Default Rear HVAC not working
I have a 2004 Trailblazer EXT LS with the I6.
I recently bought it and noticed that the rear blower is not working. I bought it anyways thinking easy fix.
Here's what I've discovered. Can not find any blown fuses. I have 5v power to the front switch. If I turn key on engine off and turn the rear fan on with the front switch and just leave it for a while, after about 10 minutes the blower will start working and run as long as I don't touch it. But, as soon as I turn the key off and back on, I have to wait 10 minutes again.
If I start the trailblazer and turn the switch on, I have let it run over half an hour and the blower will never turn on.
If I have the key on engine off and turn the front switch to R and the rear switch on, I hear a whirring noise coming from under the center console near the rear HVAC control panel.
I pulled the rear blower out and hooked it direct to battery and it works just fine.
I have checked the resistance in the front switch and also from the plug for the rear control module and the resistance is in specs with what I found on this thread
https://chevroletforum.com/forum/tra...working-42019/
Can anyone tell me either what's wrong or what else to check in order to find the problem?
Old May 26, 2015 | 1:25 PM
Malachi's Avatar
Anybody?
Old Aug 2, 2015 | 7:51 PM
Malachi's Avatar
Bump?
Old Aug 7, 2015 | 8:17 PM
Mitch167's Avatar
Hi Malachi, It sounds to me as if you have a (pussed) circuit somewhere. Where the wire connection is grounding through corrosion (puss) around the wire usually where the wires are held against the frame or body and rubbed a bit just enough to corrode.
lee7of7
Nov 9, 2017 8:10 PM
ruley73
Sep 15, 2017 8:11 AM
thompjs
Jul 6, 2015 11:18 AM
2000SuburbanK1500
Aug 1, 2011 10:43 PM
The01Cav
Aug 31, 2007 6:41 PM
