TrailBlazer 2002-2009
removing the fill plug for transfer case to check fluid level
Old Feb 7, 2021 | 7:49 PM
2MD's Avatar
2MD
Default removing the fill plug for transfer case to check fluid level
Hi.
I am seeing a lot of oil around my 2008 TB transfer case. I wanted to check the oil level but unable to remove the fill plug. My research online indicated that I need a 10mm allen wrench but what I am seeing is a 4-sided bolt plug. Is there such thing as a 4 sided wrench? What I am
looking at here and what kind of bit do I need?
Thanks.
Old Feb 7, 2021 | 9:12 PM
it's called a plug socket and they're very inexpensive
Old Feb 9, 2021 | 6:22 AM
flyboy2610's Avatar
I found that grinding down the end of the socket until it was flat helped it sit better in the plug. You need a 10 mm Allen wrench for the rear differential. Make sure you get the right fluid for the TC. You can't just throw anything in there.
baskervi1
Oct 29, 2015 8:42 AM
BigMooseBob
May 21, 2012 7:54 PM
ncseahawk
Feb 15, 2010 11:18 AM
Newkie
Apr 6, 2008 12:19 PM
dkbrucedvm
Mar 31, 2007 7:10 PM
