TrailBlazer 2002-2009
Rumble Strip Sound between 15-40 MPH
Old Aug 10, 2019 | 2:14 PM
Wes Tripple's Avatar
Default Rumble Strip Sound between 15-40 MPH
So I get this "bum bum bum" sound coming from the car when I am in between 15-40 mph. I checked the U-joints and they are solid. I spun the wheels to check the hubs and there seems to be minimal grinding if any at all. Could it be the transfer case? I'm going to change the fluid in the transfer case to see if that helps but im looking for any advice I can get.
Thanks,
Wes
Old Aug 11, 2019 | 11:45 AM
did you remove the driveshaft to check the ujoints?
Old Aug 11, 2019 | 12:40 PM
I did not. I got under the driveshaft and tried to see if the ujoints were loose in any way. I tried to turn the driveshaft with my hand and tried to wiggle ujoints. Everything was solid with no movement.
Old Aug 11, 2019 | 8:39 PM
imo, remove the driveshaft and move each joint both directions....the joints may be dry and seized.
Old Aug 15, 2019 | 8:54 PM
I have now taken the driveshaft off and checked both U-joints. Both are doing fine and can move as they are supposed to.
mirydlp
Aug 26, 2015 12:17 PM
elabenz
Jan 4, 2015 7:41 PM
Silverado18
Dec 16, 2010 8:56 PM
diggerdpilot
Apr 15, 2007 11:42 AM
jsshark1
Nov 17, 2006 2:01 PM
