TrailBlazer 2002-2009
Runs ruff
Old May 13, 2014 | 7:39 PM
kreil45's Avatar
Default Runs ruff
Ok, i have an 05 trailblazer 2WD LT with the I6. Its runs rough at idle weather stopped at a light or just starting it. Sometimes it will almost stall. It was leaking oil on the back 3 plugs. So, I the gasket replaced and replaced the plugs with factory. Had the fuel system cleaned professionally with the pressure system thing. I took it and had it checked for a miss and no miss. It to run more rough while in gear with the brake on. And no check engine light on.
Old May 16, 2014 | 6:48 AM
kreil45's Avatar
Please help!
Old Jun 11, 2014 | 6:21 PM
vipergg22's Avatar
Default idle
You say they did the fuel system but did they actually pull the throttle body and thoroughly clean that and then reset pcm ? In a very high number of cases it is usually a dirty throttle body that needs to be cleaned "or" they cleaned it but did not reset the pcm which would cause an issue also.Also make sure your air filter is clean.
Old Jun 25, 2014 | 4:53 PM
kreil45's Avatar
I don't know if they cleaner the TB and I am pretty sure they didn't reset the PCM. Can I reset the PCM my self? Yea, the air filter is almost brand new.
gonmoises
Sep 20, 2011 1:46 PM
Moebetr
Dec 16, 2010 12:19 PM
Moebetr
Sep 5, 2010 11:04 AM
chvytrk678
Dec 13, 2009 10:53 PM
Drakenheart
Jul 2, 2009 10:47 PM
