TrailBlazer 2002-2009
RWD engine put into a 4wd trailblazer
Old Dec 15, 2019 | 8:43 PM
Sheridan Gatewood's Avatar
Unhappy RWD engine put into a 4wd trailblazer
I bought a 2006 4.2 Trailblazer and the engine blew so I bought another engine and had a mechanic put it in. Turns out the engine I bought was a RWD not a 4wd but it goes down the road. I am surprised it fit with no questions, what future problems am I looking at? Do I just keep the selector at 2wd and I will be fine or am I looking at a major problem?
Help!I have searched the internet and no answers
Old Dec 15, 2019 | 9:53 PM
oilcanhenry's Avatar
If you no longer have a TC or if you still do, just keep it in 2High. Your probably going to be alright. Not sure but it migh be a good idea to pull the fuse for the actuator or unplug it that way you cant do any damage.accidentally.
Old Feb 25, 2020 | 11:38 PM
Old Smokey's Avatar
EDIT: added a part to my comment
Alright I'd like to understand this and I apologize if this counts as ghost posting but what is this all referring to? Did he buy the incorrect front differential or is there something I am missing about motors that this concerns? It was my understanding that the motor options for the trailblazer all came with a 4WD option and therefore could be swapped into a 4WD compatible vehicle, what exactly am I missing here?
I understand that if one purchased a motor and transmission together and swapped both this would of course cause an issue as a 2WD transmission is different to a 4WD compatible one and will be missing some features but couldn't this simply be fixed by mating the 4WD transmission to the new motor? the 4.2 I6 the trailblazer offered was compatible with 4WD as was the V8 the SS had, so am I missing something or what?
Old Feb 26, 2020 | 7:28 AM
Is the engine that you bought from a 2006 Trailblazer? Did the mechanic just change the engine and leave the transmission and the transfer case?
David Mercer
Sep 28, 2019 3:12 PM
DLB
Feb 1, 2018 6:35 PM
Jakob Proffer
Jan 27, 2018 5:25 AM
rkiewel
Nov 30, 2010 5:20 PM
hillbilleous
May 16, 2007 6:18 PM
