TrailBlazer 2002-2009
Shifter linkage problems
Old Feb 25, 2013 | 4:57 PM
Haplucki's Avatar
Default Shifter linkage problems
I have a 2007 Trailblazer LT3. Today the shifter acted up, when you press the button to shift into any gear it feels like the linkage is broke. When you put the gear shift into drive that is the lowest you can go, to put can in neutral you actually have to press the button in from drive.... The linkage looks ok. Does anyone have any ideas
Old Feb 26, 2013 | 8:29 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Haplucki,
I’m sorry you are experiencing this issue with your Trailblazer vehicle. I would be happy to look into this further for you. Would you please PM me your VIN, so I may proceed?
Louis
GM Customer Service
Old Feb 26, 2013 | 6:46 PM
Haplucki's Avatar
Default Shift linkage
Vin # 1GNDT13S972126410
johnmcgrady35
May 26, 2021 12:34 AM
Brandon Chandler
Dec 31, 2013 1:57 PM
dcoperator
Dec 19, 2008 6:15 PM
John Hart
May 23, 2008 10:52 AM
