TrailBlazer 2002-2009
Voltage fluctuation problem
Old Feb 4, 2013 | 7:29 PM
jpmoore70's Avatar
Default Voltage fluctuation problem
I have an 06' Trailblazer that I recently purchased. I am troubleshooting a problem with the voltage fluctuating. The gauge will fluctuate from 14+ to about 12v. This problem ONLY happens when the car reaches normal operating temperature. I have tested the voltage from the alternator while the fluctuation is happening and I get an erratic reading of approx 12-13 volts. After some research I thought it was the voltage regulator so I replaced the alternator, no luck. I am now at the point where I have nothing to troubleshoot. I am new here so let me know if any further information is needed.
Old Feb 4, 2013 | 8:15 PM
kevinkpk's Avatar
Not so sure these vehicles use a voltage regulator, but rather a module. Voltage regulator would be the first suspect in my mind. It also could be (very) dirty winding in the alternator. Since you replaced the alternator, I'd suspect the BCM.
Old Feb 4, 2013 | 8:18 PM
kevinkpk's Avatar
You might check/clean the plug in connection at the alternator
Chupp
Oct 27, 2021 7:59 AM
UP_Brewer
Mar 7, 2015 1:10 PM
ru_1980
Mar 6, 2010 10:49 AM
Scany
Sep 11, 2008 3:10 AM
cblu007
Jul 26, 2007 8:11 PM
