Front washer motor not working
2012 Traverse LT
front washer motor wasn't working so I figured it was a bad motor. It wasn't. Check the under hood fuse and its fine, check the fuse under the passenger dash and its fine. Pulled relay out that's under the passenger side dash and its fine, plus I swapped relays and still no front washer motor power. I'm not getting power at the fuse that's under the passenger side dash. From looking at a wiring diagram, power comes to the relay then to the fuse that's located under the passenger side dash. So to me it seems the issue could be the 12v wire from the battery to the relay. Anyone run across this issue?
2012 Traverse LT
Its near impossible to probe the relay slot. Its up underneath the dash and I can barely get my hand in there. I don't think it could be the switch cause looking at the wiring diagram the 12v comes from the battery to the relay then fuse.
Ok? The switch isn't in the circuit
Looks like switch to BCM, then to relay, both legs contact, and coil, then motor. The level switch is in parallel with the motor, and only let's you know if it's low, and nothing to do with the pump operation. If you can look at wire 85 when the switch is on, check for battery voltage there.
2012 Traverse LT
the Wizard
Sep 26, 2020 5:20 PM
