Rear Windshield Wiper Not Working
Old Dec 28, 2010 | 3:17 PM
dewhurstaj's Avatar
Default Rear Windshield Wiper Not Working
I have a 2004 Chevy Suburban and the rear windhsield wiper does not work on either setting. Windshield wiper fluid does not dispense either. How can I troubleshoot where exactly the fault is?
How can I check that the motor is receiving power?
Is there a fuse or relay that could need replacing?
I'm reluctant to replace the motor but how can I check to see if the motor is the problem?
Thank you for your time
-Andy
Old Dec 28, 2010 | 4:15 PM
weaponx1's Avatar
You need a volt meter to check and see if it is getting power. Also check the fuse you just might have a blown fuse.
Old Dec 29, 2010 | 10:22 AM
dewhurstaj's Avatar
I checked the fuse and it is functioning properly. How can I access the motor to see if it's receiving power? What should the voltage be on a fully functional motor?
Old Dec 29, 2010 | 8:50 PM
Go to the motor connector and check for 12V when it's on hi.
Old Dec 30, 2010 | 3:45 PM
dewhurstaj's Avatar
Default Request connect access procedure
What do I have to remove to get access to the connector?<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
The more detailed the procedure the better.<o></o>
<o> </o>
Thanks!<o></o>
Andy <o></o>
Old Dec 30, 2010 | 8:56 PM
Someone else will have to help you w/ that.
Old Dec 31, 2010 | 5:02 PM
Charlie Bucket's Avatar
Default Rear wiper/ Suburban
Same thing happened to my 2003 Suburban. The wiring in the boot at the top of the liftgate has a short in the plastic connector. You can buy a new wiring harness that runs all the way to the front for BIG bucks and rip your car appart trying to run it behind the panels or you can splice a thick wire to jump the connection as my mechanic did. For FREE!
Old Nov 3, 2014 | 12:17 PM
Allison345's Avatar
How do you know which wire to splice?
Old Mar 28, 2016 | 7:59 PM
Gov's Avatar
Gov
Default Don't forget
When doing this repair , which I found to be the ground, the tailgate must be shut in order for wiper to work. It shares the " latch closed signal. I like a fool didn't realize this and had it fixed only to not know it for another hour. Lol
weshoop
Dec 13, 2021 1:09 PM
ruley73
Sep 15, 2017 8:11 AM
otis_xing
Apr 13, 2013 2:31 PM
whymeintrouble
Jan 27, 2013 1:59 PM
