Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
No sounds in my traverse
Old Jan 15, 2018 | 12:57 PM
cheenash's Avatar
Default No sounds in my traverse
we have a 2011 traverse and there is no sounds, no chimes no radio nothing however the lights are on on the radio and signals work just NO SOUNDS... What can I do???
Old Jan 15, 2018 | 1:10 PM
The first thing to always do with electrical problems is to check all of your fuses.
Old Jan 15, 2018 | 1:34 PM
starting point; the chimes are produced by the radio and MIGHT broadcast out the l/f speaker.
Old Jan 24, 2018 | 12:14 AM
cheenash's Avatar
I have checked all fuses and their fine.. any other suggestions?
Old Jan 24, 2018 | 12:15 AM
cheenash's Avatar
Okay.. where is this located?
Old Jan 24, 2018 | 4:51 AM
check for radio fault codes with a scan tool. you will need a scan tool that reads body codes. if the radio doesn't work, you won't have chimes. if you checked all the radio fuses...pull the radio and check for power and grd at the radio wiring harness. if power and grd are present. the radio is nfg. if you replace the radio with aftermarket...you will also need a chime module to produce the chime sounds.
Old Jun 14, 2018 | 6:33 AM
vipergg22's Avatar
Your driver side speaker is probably trashed. GM used cheap $10 speakers in their cars for the standard radio and inevitibly they go bad . I have a 2008 Ascender which GM made and have replaced all 4 of mine with Pioneers and have never had another issue . All the sounds for the dash and alarms run thru the front driver side speaker .
Old Nov 11, 2019 | 4:14 PM
Norris Campbell's Avatar
Default No sound from my speakers, tho' the radio works.
could someone please tell me where to locate the speaker fuse?!
I see a fuse for EVERYTHING but the speaker fuse.
Is there even a fuse dedicated strictly for the speakers?
Old Nov 11, 2019 | 4:45 PM
no. I've never seen a speaker fuse. Shorting a speaker wire usually doesn't have any cataclysmic consequences.
Old Nov 12, 2019 | 10:18 AM
Irish_alley's Avatar
I'm here for the party
could also be an amp. my o4 imp has a radio issue where the xm radio and AM radio work just fine but theres very little sound from the FM radio
