Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
Traverse - Dead Battery?
Old Nov 8, 2018 | 4:16 PM
  #51
scottc1k's Avatar
I wanted to provide an update to my problem. I pulled the 'infotainment' fuse. I believe the 'infotainment' circuit \ module includes the Onstar feature. I thought I read on a thread where Onstar could be an issue with draining batteries when the vehicle turned off. I have left the fuse out for at least 8 months. Since doing so, I have gone the longest so far without any issue. I usually have to replace my battery two times a year with a dead cell. I am coming up on 1 year in December being the last time I replaced my battery.
Old Nov 8, 2018 | 4:44 PM
  #52
scottc1k's Avatar
I wanted to add.. I didn't drive the car for 3 days in a row recently. To my surprise, the car started after sitting for 3 days. In the past, I could have never let the car sit for more than 1 day without the battery being drained. Looking like infotainment module may be culprit. I didn't really notice any loss in features by pulling the fuse. Radio has it's own fuse.
Old Dec 21, 2019 | 1:15 AM
  #53
Stangcrazy's Avatar
Default 2009 Traverse Battery issues
Bought the car used. LOVE this vehicle. Purchased the extended warranty. Dead battery, transmission, seat heater, driver electric mirror and some other items. Continue to have dead battery issues if not driven about every three days. Now having problems with my passenger electric mirror and my passenger seat heater isn't working. Have had the locked steering wheel unable to get the key out. Seems like so many electrical problems. Just had timing belt, transmission work and can't remember what else. Will try the infotainment fuse first.
Old Mar 25, 2021 | 5:03 PM
  #54
Bruce Wallace's Avatar
Wheres the 'infotainment' fuse located? Please and thank you.
Old Mar 26, 2021 | 1:52 PM
  #55
scottc1k's Avatar
it is in fuse box under dash under glove compartment. Check manual to determine exact location i.e fuse number to pull. We still have the issue but it is not as bad as it was. During winter months we have to drive the car more. No issues during warmer months. Couldn’t go a whole week without driving though.
Old Aug 31, 2023 | 8:04 AM
  #56
FinestChunk's Avatar
Default Isn't it hilarious..
Where the high schoolers work and nobody cares about your vehicle.
DO NOT EVER take your car to the dealer if you care about it.
Aside from that, my local dealer wanted 2,400 dollars to do spark plugs bahaha. Took me 20 mins.
Thanks for actually doing some investigating and finding out.
Chevy is the biggest joke/scam to walk the earth.
THIS CAR LEFT ME STRANDED IN UTAH. all because of some trash xm / on star crap.
[Edited. -mod]
Old Apr 11, 2024 | 10:44 PM
  #57
charlesjs3718's Avatar
Default I’m having the same issue
Originally Posted by soontobestranded
After 2 years of putting up with Traverse dying. GM finally paid up. They sent me a check for a more than fair price, they also paid my lawyer pretty handsomely too. The seventh time it was in the shop, they did find an Onstar module intermittently drawing power and replaced it. That seemed to fix it but we were already deep into our lawsuit. My wife absolutely loves her Explorer.
who did u contact as a lawyer because I’m still making payments on mine as well and the dealer can’t seem to find what’s wrong with it
Old Apr 11, 2024 | 10:58 PM
  #58
@charlesjs3718 That person hasn't been here in sixteen years.
Old Apr 30, 2024 | 5:38 PM
  #59
scottc1k's Avatar
I wanted to thank you for posting this message. It looks like it may have resolved this issue for me. Based on the OnStar comment posted, I called my mechanic and he said the Onstar is in fact a known issue. My mechanic said to pull the Onstar fuse. It is located on the negative battery terminal lead that connects to the battery. There is a little black box on the negative lead and you just pull it out of that black box. There is a YouTube video on it as well. After pulling it, I noticed the onstar light on my mirror did go out. Since then I have been taking voltage readings on my battery and they have been holding steady at 12.5 volts. So this is looking like the solution. I called the dealer as well and they mentioned replacing the onstar module for $750. They never mentioned pulling the fuse as an option. So apparently my other posts about onstar being on the infotainment fuse was incorrect. Onstar has its own fuse.
Old Jan 17, 2025 | 4:00 AM
  #60
OztechBuilders's Avatar
A dead battery in a Chevrolet Traverse can disrupt your plans, but it's an issue that can often be resolved easily. Common signs include the engine failing to start, dim lights, or electronics not working. Causes range from leaving accessories on to battery age or weather conditions.
Steps to Address:
  1. Jump-Start the Battery: Use jumper cables or a portable jump starter to revive the battery.
  2. Inspect the Battery: Check for corrosion or loose terminals that might be affecting the connection.
  3. Test the Battery: Use a multimeter to confirm if the battery needs replacement.
If you frequently park your Traverse under roof awnings, ensure there's sufficient ventilation to avoid excessive heat buildup, which can shorten battery life.
