Traverse Chevrolet's full size Crossover. Introduced in the model year 2009, the Traverse is a stylish and highly fuel efficient cross between a powerful SUV and a spacious minivan.
2014 Chevrolet Traverse
Platform: Lambda
Where do I get ignition powered 12V from the passenger side electrical box
Old Feb 9, 2010 | 9:52 PM
Jesper Jensen's Avatar
Default Where do I get ignition powered 12V from the passenger side electrical box
I am running a radar detector hard-wire and would like ignition power 12V and not always on. Which fuse or power supply can I use. Right now I am using the seat heating/cooling power source - but it seems to be always on.
Old Feb 12, 2010 | 3:00 PM
rbarrios's Avatar
I read a forum where a member installed a Parrot bluetooth kit-
I believe he ran a power wire to the fuse box under the hood- as theres an extra powered fuse there-- whose power also goes out after 10 min.
Old Feb 16, 2010 | 12:09 AM
s34n's Avatar
just take a quick splice and connect your radar detector wire to your ignition wire. ill find a pic of one.
http://shop.oreillyauto.com/ProductD...goryCode=3067E
Old Feb 20, 2010 | 11:02 PM
charlie pachanga's Avatar
Would not suggest tieing into ignition wires at ignition harness. Those are low voltage/amperage. There is a switched (RAP) circiut at BCM.
Old Feb 20, 2010 | 11:13 PM
s34n's Avatar
a radar detector is low voltage also. probably be ok to tie it into where the ignition wire goes up to the ignition under the steering column.
Old Mar 9, 2010 | 1:32 PM
rbarrios's Avatar
someone sells a wire that allows you to plug into the power in the rear view mirror...
if you have onstar/camera etc... you can plug in directly here....
here you go...
http://www.invisicord.com/
teksector
Oct 3, 2013 9:45 PM
jbuszkie
May 28, 2013 11:41 AM
holophonervirtuoso
Cobalt
May 17, 2010 3:43 AM
Opera_Rat
Jan 15, 2010 10:34 PM
STiYLIN
Jun 7, 2007 1:06 PM
