Trax Chevrolet's subcompact crossover SUV. This small SUV has a pioneer spirit, with modern technologies that make discovery easy and cargo space that molds to your lifestyle.
2017 Chevrolet Trax
Platform: Gamma II
Heater in 2018 Trax
Old December 10th, 2019 | 5:59 PM
caryrae73's Avatar
Default Heater in 2018 Trax
We bought my wife a used 2018 Trax earlier this year and she had me feel the heat coming from the vents because they don’t seem to switch between defrost, front vents or feet. It feels like every vent is open because I feel air coming out every vent no matter what position I choose. Anyone know what may be causing this before I have to take it in? If it’s an easy fix I’d rather do it myself.
Old December 11th, 2019 | 7:41 AM
Sounds like it could be the mode actuator is bad or the mode door is broken. Not familiar with the Trax but it is under the dash.
Old December 18th, 2019 | 12:16 AM
Robert Olson's Avatar
Default ?
I'm guessing you don't have a factory warranty.. I tell people all the time. Don't go over the milage before the time runs out on the warranties. If you're going to you have to buy a extended warranty. I'm sorry that happened to you. I use my car as direct by the warranty. Warranty says only 12,000 a year. Then I follow it to the letter. Never wistfully drive. (((((Sounds like a blown fuse)))))) check your fuse box. Once a month you should always check tire pressure, fluids, buttons, levers, electronic, fuses and more. It has a turbo. I hope you're checking your oil daily. It naturally burns oil.
Old December 18th, 2019 | 5:08 AM
oilcanhenry's Avatar
Happened all of a sudden check fuses. Might be bad wires too.
Stormyj
2014 - 2018 (GMT-K2)
18
June 13th, 2024 6:07 PM
JasonD
December 6th, 2019 5:43 PM
Darens
September 1st, 2018 10:29 PM
rivman
October 27th, 2017 2:12 PM
cujo8
October 28th, 2008 11:02 AM
Quick Reply: Heater in 2018 Trax
