Uplander 2005-2009
Platform: U-Body
06 Uplander cooling problem
Old May 13, 2021 | 4:37 PM
Frank Boffi's Avatar
Default 06 Uplander cooling problem
Today my 06 Uplanders temp gauge shot up to red and bells went off. Pulled over, no overheating, no leaking water, no steam, nothing ! Hoses were dry, no leaks on ground. Only thing odd was overflow container was full of rusty , nasty looking anti freeze. Waited about 25 minutes and temp gauge was back at halfway again. Everything seemed fine but had it towed to mechanic as I didn't want to drive it. Any suggestions on what it might be ?
Old May 14, 2021 | 1:06 AM
oilcanhenry's Avatar
The most likely culprit in the thermostat got stuck. The fact that the coolant was rusty means your cooling system needs cleaning, so the thermostat got stuck.
Old May 14, 2021 | 11:36 PM
when the system overheats the coolant volume expands and the excess will overflow into the reservoir.
+1 thermostat is a good place to start.
Old May 7, 2022 | 11:02 PM
Marielynn's Avatar
We are having the same problem. We have replaced the water pump, radiator, radiator cap, hoses, thermostat, bleeding tower, cleaned out all the rusty looking water, the double fan, and lines. It still about a mile down the road it’s reading hot! We can not figure out why.
Old Oct 5, 2022 | 7:06 PM
Smokeater87's Avatar
Ours too!!! Replaced everything and flushed everything even eliminated heater cores and still overheating!!! Water pump thermostat radiator cap all replaced and every single line flushed and radiator flushed out all super clean no leaks not sure what the issue is and no smoking and no coolant in the oil
tjctransport
Jul 22, 2016 11:44 PM
1969fb4me
Uplander
Jan 26, 2013 11:03 AM
jsehoule
Uplander
Feb 4, 2011 11:36 AM
Abdo57
Uplander
Feb 12, 2010 5:11 PM
