Uplander 2005-2009
Platform: U-Body
2006 uplander with erratic fuel gauge
Old Jun 7, 2011 | 10:53 AM
Firemike262's Avatar
Angry 2006 uplander with erratic fuel gauge
Filled up our 2006 Uplander yesterday morning and my wife drove less than 30 miles before she called me complaining that the fuel gauge showed just over half a tank, then when I checked the gauge after getting home the gauge initially peaked at about 3/4 tank then bottomed out on E and the low fuel "idiot" light came on. Any ideas what's wrong and how easy and expensive it is to fix? Thanks.
Old Jun 8, 2011 | 10:38 AM
Official GM Rep
Firemike262,
I am sorry to hear that you are experiencing this issue. Have you spoken with your local dealership about this issue?
Thank you
Elizabeth, Chevrolet Customer Service
Old Jun 8, 2011 | 1:23 PM
belleaudb's Avatar
If you live near any Oreilly auto parts, they currently have Chevron Techron Concentrate Plus additive on sale, 2 for 1. You must use the Concentrate Plus, not regular injector cleaner. This product has an additive to clean and protect the sending unit contacts.
This is also sold at GM dealerships with a GM label on it.
Bulletin No.: 05-00-89-078B
Date: February 06, 2008
INFORMATION
Subject:
GM Fuel System Treatment PLUS Fuel Sending Unit Corrosion and Fuel System Deposits Models:
2008 and Prior GM Passenger Cars and Trucks (including Saturn)
2008 and Prior HUMMER H2, H3
2005-2008 Saab 9-7X Supercede:
This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 05-00-89-078A (Section 00 - General Information).
The GM Fuel System Treatment PLUS is not recommended for use with diesel fuel. The GM Fuel System Treatment PLUS is specially formulated for use in gasoline and/or E85 fuels.
GM Fuel System Treatment PLUS P/N 88861011 (for U.S. ACDelco(R) use 88861013) (in Canada 88861012) is now available for use in gasoline engines.
Added Benefits and Uses
The PLUS portion of GM Fuel System Treatment PLUS is the addition of a filmer additive that when used regularly can protect fuel system sending units from the corrosive effects of certain sulfur contaminants found in some of todays gasoline.
Sulfur contamination can disrupt electrical continuity of certain fuel sending units and lead to erratic or false fuel gauge readings. With scheduled usage GM Fuel System Treatment PLUS protects against the effects of harmful sulfurs in gasoline.
The Four Benefits
Just pour in one bottle of the GM Fuel System Treatment PLUS into the fuel tank when refueling around each oil change interval:
Cleans - Sulfur corrosion from fuel gauge sending units.
Prevents - Harmful sulfur components from attacking sensitive fuel system electronics.
Protects - By coating metallic surfaces of the fuel system.
Removes - Engine deposits left from use of poor quality fuels.
gamato
Jul 6, 2020 6:06 PM
baby141
Feb 24, 2016 10:56 AM
jrmontes19
May 1, 2015 3:48 PM
santa6
Jun 23, 2013 2:14 PM
Robertwav1
Aug 1, 2007 7:54 AM
