Uplander 2005-2009
Platform: U-Body
2007 Uplander 3.9L Coolant Leak from heater IL/OL Pipe
Old Mar 5, 2018 | 7:06 PM
momofgcm's Avatar
Newly Registered
Default 2007 Uplander 3.9L Coolant Leak from heater IL/OL Pipe
My 2007 Uplander is leaking from the heater IL/OL pipe. The part is discontinued and I can't find one at the junk yard. PN 12603835.
Anyone have a suggestion for how to repair this or an alternative source for the pipe? I do not want to scrap the vehicle for a $50 pipe!
Old Apr 25, 2018 | 7:47 PM
swindels38's Avatar
New User
Awaiting E-mail Confirmation
I had the same problem, had to cut the bad out and replace with heater hose.
Old May 13, 2020 | 5:03 PM
Tom mg's Avatar
What solution did you come up with?
dealing with the same problem on a delivery vehicle
Old May 13, 2020 | 6:05 PM
12three's Avatar
is that a metal one?
junkyard, weld it, replace with rubber
Old Jul 24, 2020 | 9:21 AM
12three's Avatar
i found it at the junkyard after mine developed a pin hole.
replace the other metal line while you are at it. it is actually available at most part stores. the clamps needed to go too, they seemed fine until i flushed the system with a garden hose and then the leak was readily apparent.
the T that goes to the engine oil cooler is metal too... it likely needs replacing at the same time. i used a $5 dorman T measuring 5/8 x 5/8 x 3/8 then a molded hose from advance auto for $10 where, if you snipped it in half it would replicate the two pieces of 5/8 needed to attach to the T... let me know if you need the part numbers. saved $15+ and the long wait for the delco T and hose...
William Harcourt
Uplander
Sep 23, 2017 12:24 AM
Viking08
Sep 28, 2015 8:44 PM
JoeCB
Nov 21, 2013 12:11 PM
gaftop1
Apr 8, 2012 12:33 PM
twenty8
May 22, 2008 7:21 PM
