Uplander 2005-2009
Platform: U-Body
2008 uplander cooling fans on high
Old Dec 21, 2014 | 6:51 PM
Mat's Avatar
Mat
Default 2008 uplander cooling fans on high
The engine cooling fans turn on high about 10 seconds after starting my van. The a/c compressor clutch does not engage. I replaced the high pressure a/c switch thinking that the high pressures might be too high. No luck! Retrieved code P0532 the other day. Has anyone ever seen this problem before? Thanks.
Old Dec 24, 2014 | 12:58 PM
442dude's Avatar
Have you checked the charge of the AC system?...maybe you need to recharge with refrigerant or pressure is too high in the system? Both of those could set off that code as well as the sensor that you replaced being bad.
Old Dec 25, 2014 | 2:34 PM
Mat's Avatar
Mat
Will check the refrigerant level. Thanks for the reply
Morph1949
Uplander
Feb 16, 2015 2:34 PM
ads_210
Dec 11, 2008 6:43 PM
Silverado02
Dec 8, 2008 12:28 PM
SilveradoLS02
Aug 12, 2008 8:45 PM
