Uplander 2005-2009
Platform: U-Body
2008 Uplander towing limit
Old May 6, 2015 | 10:28 AM
KINGTROT1964's Avatar
Default 2008 Uplander towing limit ?
How much can I safely tow without a trans cooler installed ?
I have a 3.9 V6 and I plan on towing a 5' x 8' box trailer (900 lbs. empty) from northeast Ohio, across PA to New Jersey next week. I am estimating our payload to be around our 1000 - 1200 lbs. max.
Old May 29, 2018 | 10:47 AM
yjf1535's Avatar
Sorry for the late response but you should be fine. The Max trailer weight is 3,500 Lbs.
Old Sep 15, 2018 | 9:43 AM
12three's Avatar
does anyone know the catch points for the 3500lb rating? can this be increased?
i have a 3.9L, tranny cooler, and 6 lugs... but i have the same rated 3500lb tow capacity as a 3.5L without a tranny cooler and 5lugs.... my hitch says 5,000lb max and i assume that reese took into account the fasteners they provided and the preexisting weldnuts they instructed to use in the directions...
so i wonder how much closer the 3.9L with tranny coole, and 6 lugs could get to 5,000lb than the 3.5L without a cooler and 5 lugs....
Old Sep 20, 2018 | 12:24 PM
yjf1535's Avatar
I have a 2008 with a 3.9 L. I have added a transmission cooler and air shocks. I pull a 3500 LB camper and it really struggles on the big hills here in SW Missouri. I would be very hesitant to try to pull more than 3500 Lbs,
Old Sep 20, 2018 | 1:07 PM
12three's Avatar
good to know.
is your camper 3500lbs loaded or unloaded?
do the brakes seem like they are enough?
my brakes feel a bit lacking with 650lb in the vans cargo area.. my rotors are thin and i dont know what kind of pads are on it from the prior owner
Old Sep 21, 2018 | 11:31 AM
yjf1535's Avatar
The trailer is probably closer to 3600 Lbs. Loaded. I put very little in it to save on weight. We buy groceries and ice etc, close to where we camp. The trailer has electric brakes and does well. As a note on the brakes before we got the camper, the brakes worked well but I did notice that the rear brake pads wore out before the front. I bought the 2008 Uplander when it was new and have had to change the pads on the back every 50,000 miles. I suspect I will need to change them a little sooner now that we pull the camper.
impala2006ls
Sep 25, 2025 5:43 PM
Chevrolet Forum News
Sep 6, 2013 5:38 PM
TMoore05
Sep 16, 2012 10:13 AM
wtroger
Jul 26, 2011 7:33 PM
the_vigilante
Feb 2, 2008 11:09 PM
