Uplander 2005-2009
Platform: U-Body
check engine scan question
Old Jul 20, 2011 | 6:38 PM
07chevyuplander's Avatar
Default check engine scan question
my sister has a 07 uplander with the 3900 in it and the check motor light is on, however when we scan it the tool says ecu not detected, same thing with 3 diffrent scan tools, any help here will be awsome, the van has 110,000 on it so its out of warrenty also the fuel gauge will say like 300 than when u turn it off and start it ul get low fuel, than turn it off and start and ull get like 250
Old Jul 20, 2011 | 7:26 PM
EinST's Avatar
Welcome to the forum. The scanners are probably not seeing the battery voltage on the DLC connector pin 16. Check the 10A OnStar fuse in the I/P fuse block?
Old Jul 20, 2011 | 11:59 PM
ill check it out in the morning, is that the fuse block on the passanger side?
BMWTECHNICIAN
10
Apr 28, 2010 6:38 PM
maxxman04
Jan 7, 2010 9:21 PM
in2pro
Apr 20, 2008 3:31 PM
chevygirl1
Nov 12, 2007 8:08 AM
Revredneck
Feb 22, 2007 1:56 PM
