Uplander 2005-2009
Platform: U-Body
Old Jul 24, 2015, 4:25 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine and Powertrian
Print Wikipost
Electrical "problems" with 2008 Chevy Uplander LS extended van
Old Feb 2, 2013 | 7:21 PM
  #41
rschem's Avatar
Question battery terminal
I just bought a 2009 uplander.Checking under the hood I noticed th + terminal bolt is loose. This could cause a lot of power/alternator troubles.Has anyone else found this condition?
Old Feb 3, 2013 | 9:09 PM
  #42
ssilk40's Avatar
omg SEE IF ITS A PROBLEM WITH A SOLENOID FLOODING THE ENGINE... JUST GOT THIS ON MINE TOOK A WEEK TO FIGURE OUT AND FIX.
Old Feb 4, 2013 | 7:17 AM
  #43
Papa Bear's Avatar
What solenoid are you talking about? Do you mean fuel injector?
Old Apr 3, 2013 | 7:32 AM
  #44
bellamr's Avatar
Default "Charging System Failure" Fixed on my (Canadian) 2009 Montana SV6
Originally Posted by mgeorge77
Hello,
I'm having the same issue. Charging system failure light came on about a month ago but didn't last long. A week ago it started with more frequency and battery saver came on while in park. Last night while on a long trip 150 plus mile, the Charging System Failure light came on again and then the Battery Saver light comes on. When that happens everything but the motor shuts down. A/C, Radio ect. Went to Walmart replaced the battery, and of course no change, issue still persists.
Please let me know if anyone has found a resolution. So far people are saying it could be Voltage Regulator or Alternator.
Hello all,
I found another post on the interwebs that indicated that there is a systemic problem with the bolt on the starter holding the cables connected to the starter and alternator can be loose. Sure enough, I went under the van and found my bolt on the starter was loose as well. I tightened it up with a 13mm ratcheting box wrench (it is difficult to get at) and that fixed the problem.
Thanks to all of the posts here and elsewhere that allowed me to fix the problem and not get raped by a dishonest mechanic (and they are not all dishonest) at a stealership.
Old Apr 3, 2013 | 11:48 AM
  #45
Papa Bear's Avatar
Thanks for the update !!
We need that kind of feedback.
Old Apr 4, 2013 | 5:03 AM
  #46
carllucas's Avatar
Originally Posted by Chevrolet Customer Service
carllucas, have you spoken with your dealership about a possible diagnosis of your vehicle? This could serve as a starting point for you to fix the vehicle yourself or, if you feel their prices reasonable for the work prescribed, you could have it fixed there as well. I hope this helps you.
Jeff Morris, Chevrolet Customer Service
No I did not
I got it myself done .
The alternator did all that hassle .
I did change the alternator and everything
works fine. The best .
Old Jan 28, 2014 | 9:41 AM
  #47
whitewolf2828's Avatar
Default 08 uplander help
katmiles123, I would like to direct message you about your issue. Thank you for your time.
has anyone found any new info on this electrical problem because im going broke and of course chevy don't seem to want to know who are unless your at the dealership to buy a new car
Old Feb 8, 2014 | 11:48 PM
  #48
niceguy88's Avatar
If you notice throughout this thread, most if not all charging/electrical issues point to a faulty alternator/regulator.
I've had my '08 Cargo van for over 3 years, have a modest sound system in it (upgraded fronts, 12" sub, 4 channel amp), and have never had any electrical issues.
I have however also replaced the battery once the original left me stranded.
Old Feb 12, 2014 | 7:26 PM
  #49
Jasonchallis's Avatar
Hi.. What problems are you having? Need to know symptoms
Old Mar 28, 2014 | 7:56 PM
  #50
Kwest's Avatar
I've been having the exact same problems as noted here. I bought my Chevy Uplander 2008 in 2012. A few months later, one problem I did have was with the neutral safety switch which very rarely will act up and I won't be able to start the car unless its in neutral. It happens so seldom (only five times since I've had it) that I haven't really bothered too look into it.
So a couple weeks ago, I was on my way to another part of town and I looked down at my dash and saw the message "CHARGING SYSTEM FAILURE". I freaked and automatically turned around and headed home. As I continued to drive, another message came on alternately that read "BATTERY SAVER ON" or something like that. I just wanted to get home before something else happened. Then all of the dashboard warnings came on at the same time: ABS, TC (traction control) and CHECK ANTI-THEFT SYSTEM, etc. I was convinced the car would leave me stranded. A few minutes later, I looked down and all of the lights had gone out and everything was normal again. But I wasn't going to take any chances so I took it straight home hoping to catch my mechanic before he closed shop.
I wasn't able to get there in time but since Im currently on disability, I knew I'd have plenty of time to catch him. Well I didn't take the car to him right away. I mentioned it to a friend and he said it might be a bad terminal or something. To me, it sounded like some kind of short circuit. Anyway, I checked the terminals and they all seemed fine.
Two days ago, I had to go downtown for some business. I drove down to a residential area where I wouldn't have to pay for parking and I walked from there into the city. After I parked the car, I noticed it was slightly out of line with the curb so I got back in to reposition it and the damn thing wouldn't start and all those same dashboard lights came on again only this time, the locks started to lock and unlock themselves repeatedly, the gauge needles began to shake and the horn started blowing. It would all stop when I turned the car off. I repeated this three times and each time, the same results. I left the car and walked into the city to conduct my business. An hour and a half later, I walked back to my car, praying it would start but figuring I'd need a tow truck to haul it to a Pep Boys or something. To my surprise it started and I was able to get it back home.
Yesterday, I took it to my mechanic and told him what's happened. Of course, none of this poltergeist mess happened when I drove the car there. He called me an hour later. He said he checked the alternator and everything was fine. He replaced my battery (which Im sure was fine but he had to make some money off of me like always) and said that might be the issue which I doubt. So now Im just waiting around to see if this crap happens again. Im trying not to take my car to a dealership. I bought the car used and my warranty expired last August. I don't want to get raked over the coals since I know they design these cars so only they know what's really wrong with these cars.
From reading this thread looks like Im not the only one having a problem so Im glad I googled it and found you guys. So has anybody found any answers or solutions to what's going on with these vans? I have to go to Boston in another month and a half and I can't have this problem. Any help would be appreciated. Thanks.
