Uplander 2005-2009
Platform: U-Body
Is an Engine Oil cooler needed?
Old Apr 8, 2020 | 10:58 AM
  #11
12three's Avatar
some uplanders come with a stock engine oil cooler...
i was wondering if anyone has replaced one?
it is a sandwich type that goes between the motor and oil filter
https://www.rockauto.com/en/moreinfo...433507&jsn=252
chilton manual claims its simple on a 3.9L uplander with maybe the exception of getting the coolant hose clamps off... but ive seen these be a bear on other chevys
ive vaguely heard of an uplander have a faulty cooler causing oil in coolant. he didnt say if he had coolant in oil too.
my symptom is oil in coolant WITHOUT coolant in oil
i believe the cooler primarily appears on 3.9L motors in the following: BUICK LUCERNE 2009-2011 BUICK TERRAZA 2006-2007 CHEVROLET UPLANDER 2006-2009 PONTIAC G6 2006-2007 PONTIAC MONTANA 2006-2009 SATURN RELAY 2006-2007
but i have seen similar ones pulled from 3.4l azteks and i believe a 3.8L venture too
due to the $200 price tag i am looking at junkyards. not sure how to test it or diagnose it on the vehicle (or off, for that matter). the new gasket was $15.
it may be possible to bypass the cooler by connecting the inlet and outlet hoses with a double barb coupler... i guess it would leak oil out the cooler's barbs if defective... the cooler hoses are molded and there may not be room to do a simple bypass job...
Old Apr 8, 2020 | 7:43 PM
  #12
you can bypass it. just get some hose and clamps the cooling system get to approx. 17psi and the engine oil maybe 60ish on a cold start
if you want to save the stock set up...this part could be had cheap at pick and pull. if it uses any seals, buy those new
leetoy
Sep 6, 2017 3:32 PM
slugranch
Oct 2, 2015 3:43 AM
2500Silverado6.0
Mar 18, 2015 10:26 PM
zagfan1989
Sep 27, 2011 12:42 PM
bonito
Jun 25, 2011 1:41 PM
