Uplander 2005-2009
Platform: U-Body
Help problems with 2008 uplander
Old Mar 17, 2014 | 1:09 AM
Keithpetriejr's Avatar
Default Help problems with 2008 uplander
Hi I'm having a problem with my2008 Chevy uplander the daytime lights and washer fluid won't stop running even when it's not turned on
Old Mar 18, 2014 | 7:40 PM
442dude's Avatar
Both started doing it at the same time? Otherwise its likely a relay with the DRLs and the wiper stalk for the washer pump. The relay for the DRLs should be in the underhood fuse box and you know where the stalk is...
A long shot answer if they both started doing it at the same time would be that the body control module (aka BCM) is failing. Try disconnecting the battery for 10 minutes and reconnecting. sadly its a dealer only repair as they need a Tech 2 to program the new one...unless your local mechanic has one...
I'm hoping its my first guess....
Old Mar 19, 2014 | 9:39 PM
Official GM Rep
Hi Keithpetriejr,
I'm sorry to hear of this problem with your Uplander. I will like to take a further look into your concern. Please send a private message if we can be of any assistance. In the message please include your full name, VIN, current mileage, and the name of your dealership. We look forward to hearing from you!
Kristen A.
Chevrolet Customer Care
G P Meyers
Uplander
77
Apr 15, 2020 2:37 PM
Keithpetriejr
Sep 4, 2018 1:49 AM
kimble
Uplander
Aug 4, 2014 8:17 PM
draysk8
Uplander
Jul 11, 2012 10:33 AM
cmarcin
Jan 15, 2007 2:49 PM
