Uplander 2005-2009
Platform: U-Body
Overheating Mystery
Old Aug 24, 2017 | 5:13 PM
  #11
kevinkpk's Avatar
There are two screws holding the tsat housing, I believe they are 15mm. Unscrew the screws, remove the exisiting tstat. Now comes the fun part, after you clean the gasket of both surfaces, you have to reinstall the new tstat. The issue is with starting the screw with the new gasket, this is just mechanical experience.
Old Aug 26, 2017 | 7:38 AM
  #12
Conrad Cody Cline's Avatar
Would you be able to give me some idea of where to find the tstat. I do not remember seeing anything around the end of the hose or around the bleeder valve above or below it. I am pretty sure that to some extent I was blind, but any help you can give on locating it would be helpful.
Old Aug 26, 2017 | 8:11 AM
  #13
kevinkpk's Avatar
Old Nov 19, 2019 | 9:50 PM
  #14
steven burdge's Avatar
Default There is a very good Chevy uplander video on YouTube.com
that will tell you everything you need to know.
Old Jan 18, 2021 | 5:21 PM
  #15
David Edmond's Avatar
I did. I followed the top hose to the metal joint it connects to. There was no thermostat or thermostat housing. Its where one of the two bleeder valves are (in the metal joint). I took off the hose and it was dry with no sludge, and no drainage of coolant. Which is why i am assuming there is too much air in the line. I have a thermostat sitting here waiting to be used, but I cannot find the thermostat in the vehicle. The lower house also had no thermostat on it. I looked around ,and while I did not take off the throttle control housing I did check under it (after removing the air intake hose) and could not see anywhere the thermostat would be. Its all essentially solid metal under there with no radiator hose going under the Throttle control housing. I might be blind, and thats a good possibility, but I didn't see anywhere the thermostat would be.
Pardon the bad editing on the image .
you have to remove the throttle body to access the tstat housing.
Old Mar 1, 2021 | 4:09 PM
  #16
David Montgomery's Avatar
The screws are 13 mm, and you have to remove the throttle body assembly to access it, or remove the exhaust crossover. Good luck with the latter, be prepared to break some bolts! I just did one on a 2005 Uplander, but the weird overheat problem still exists. Ran a pressure test, no leaks. Radiator appears clear of sludge, however their sure wasn't much coolant that drained before I started, and it was all the way to the top of the radiator.
Old May 5, 2024 | 4:22 PM
  #17
weatherdwings's Avatar
Default overheat
Trace the top radiator hose to the engine, at the end of the hose is the tstat.
What’s a tstat?? I just got a used Chevy 2006 Uplander and mines doing the same thing
Old May 5, 2024 | 4:23 PM
  #18
Default mine too!!
I need a little help here. I have a small mystery I am trying to figure out. I have a 2006 Chevy Uplander 3.5L. For the last few months the vehicle has been acting weird with overheating.
During idling or driving it will randomly creep up in heat and then drop down after a minute or two. Sometimes it gets into the red, other times it just goes up a few notches. It never stays there and always comes back down. Then, Sometimes it dips slightly under normal.
At first I though it was the thermostat, and still think it might be. I couldn't find the location and got some tips on where it is located from a friend who manages an auto-zone. I still couldn't find it. He said it as under the throttle control housing, but I couldn't find it. I did however check a bleeder and found very little gunk in it and took that out and put it back. I also found some brown sludge under the radiator cap, but there was nothing in the hose running to the engine block and none going too deep into the radiator. I was running the car on idle and could feel hot on the upper and lower hoses to the radiator. It seemed like everything was flowing fine.
I burped the radiator in a crude way, by simply taking off the cap and letting it run. For about a minute or two it was like a boiling pot with some coolant coming out and plenty of bubbles, but then it stopped and no more coolant was rising to come out. I ran the vehicle around town and didn't get a single issue with it. Then I make a sharp turn and it rose up slightly and then went back down. I then parked on an incline (front end higher than back) and was holding the rpms around 3500 it started to creep up again. Until it was near red line. Then as I pulled forward and drove home it went back down and was normal the rest of the ride.
Since then the issue has persisted in much the same manner. It will run just perfect for a while, and then randomly creep up and go back down. It doesnt matter if I run the heater or the air. It doesnt matter if I have been driving for 5 minutes or 50. Ive driven for an hour without issue and then another day just starting the car and letting it idle for a minute causes issue.
From my belief I would say that it could be either the thermostat or air in the coolant. It is worth noting that our heat in the vehicle has not worked for a few years. Of course we are in the south and heat is not a big issue. Neither the back nor the front heating vents blow hot.
I just got to use 2006 Chevy Leonard doing the same thing did you ever figure out what it was and could you please let me
Old May 5, 2024 | 10:24 PM
  #19
@weatherdwings
please pay attention to dates. Conrad hasn't been here in seven years and won't answer you. Plus, there are many causes for overheating so his fix might not help you.
Please, instead of just posting "me too", always list your particular symptoms as you see them,vehicle details (engine? miles?) , list the troubleshooting steps you tried and results from the suggestions given in this thread.
Old Jan 28, 2025 | 5:14 PM
  #20
Bjane91's Avatar
I appreciate the responses.
I can assure you that there is no mud in the fans and that they are spinning freely. I would also like to change the thermostat but I cannot locate it. I cannot find anyone who can tell me where it is and I dont want to spend 250 bucks for a mechanic to fix a 10 dollar part. I may have to, but I will go down fighting if I must.
We've been using premixed coolant, not straight. Most of it is peak performance brand from the local dollar general. I live in a very rural area, so brand selection is minuscule.
I just spend 250 Friday on a Mechanic to replace my thermostat and my hoses but almost my water pump has already been replace 10 months ago vehicle still overheating.. so the mechanic wanted me to turn around get a another new water pump to see of that'd the problem my fans work just fine . The Radiator was replaced almost two years ago .
xwinterx
Apr 16, 2017 6:15 PM
Melissa82
Nov 13, 2016 10:51 AM
Chameleon
Dec 3, 2012 10:21 AM
tom5170
Jun 9, 2010 12:13 AM
PendO
Nov 6, 2007 12:59 AM
