Uplander 2005-2009
Platform: U-Body
P0128 code but dash reads normal?
Old Nov 24, 2012 | 4:34 PM
doug5g's Avatar
Default P0128 code but dash reads normal?
2005 Uplander 3.5L. I am getting a check engine light with code P0128 "engine temperature has not increased and/or reached the correct level within a specified amount of time after engine startup". My guage on the dash reads normal and heat blows out perfectly. The coolant expansion tank looked a little low but the radiator was full and I added more coolant to the tank.
1. Are there two different sensors i.e. one for the dash and one for the computer?
2. Could this just be a thermostat?
Thanks
Doug
Doug
Old Nov 24, 2012 | 4:49 PM
1.one sensor monitor coolant temp and info is sent from the ecm to the guage via serial data line communication
2.usually it is a thermostat issue.
Old Nov 24, 2012 | 4:56 PM
doug5g's Avatar
What temp thormostat should be used in a 2005 Uplander?
RazzMaTazz
Mar 18, 2015 7:09 PM
Buckeyegrad02
Jan 12, 2011 2:05 PM
pepq105
Jan 10, 2010 9:24 PM
Slvr Malibu
Sep 5, 2009 4:54 PM
tankerpilot01
Dec 26, 2007 5:27 PM
