Uplander 2005-2009
Platform: U-Body
P0445 Code
Old Aug 11, 2011 | 8:45 PM
zx6rf7's Avatar
Default P0445 Code
Hi
I have my check engine light and check gas cap warning coming on I had the code read and I got the a P0445 code I have tried an aftermarket gas cap and the gas cap off my 2008 silverado and the warnings keep coming. From what I have read it is the evap system problem but where do I start??
Old Aug 12, 2011 | 1:07 PM
EinST's Avatar
Welcome to the forum. P0445 is an EVAP purge control circuit malfunction. If there's a slight leak at the EVAP purge valve as a result, it can cause the "CHECK GAS CAP" warning as a secondary effect.
Old Aug 14, 2011 | 7:52 PM
zx6rf7's Avatar
thanks for your help I will start there that is located at the side of the fuel tank??
Old Aug 14, 2011 | 8:14 PM
EinST's Avatar
You're quite welcome. The EVAP purge valve is in the engine compartment. Mind, you either have one problem or two problems. It's your money but I hope you aren't going to throw parts at it.
Old Aug 15, 2011 | 7:31 PM
zx6rf7's Avatar
Thanks I will try to find it tomorrow, I looked once but I guess not hard enough I am going to check out the condition of the valve and lines and then decided weather to change parts or take it in to have it fixed
Old Aug 30, 2011 | 7:53 PM
zx6rf7's Avatar
Well I changed the purge valve and all the lines I can't find anything wrong but the light is still on, but the check gas cap light only comes on every few starts. Also I am not sure if this is related or not every once and a while it does not like to start you turn the key but it doesn't want to fire, shut it off and back on it fights a bit but it starts, any ideas???
Thanks
Old Aug 30, 2011 | 10:05 PM
EinST's Avatar
That's what I was afraid of. If the purge valve is new and you're still getting P0445 (are you?), then the fault is probably electrical, either in the wiring or ECM itself. In addition, it must be intermittently failing the EVAP leak test (actually leaking or FTP sensor fault?). As luck would have it, it's really not feasible to work on EVAP problems without a smoke machine and professional level scan tool. It looks like you'll have to take it in for service.
Old Aug 31, 2011 | 4:44 AM
zx6rf7's Avatar
That what I figured its like looking for a needle in a hay stack thanks for your help I'll let u know when I take it in what it was
Thanks
Old Aug 31, 2011 | 7:32 AM
Papa Bear's Avatar
What year, model and mileage is your vehicle? Are you the original owner?
Old Sep 1, 2011 | 4:47 AM
zx6rf7's Avatar
Papa Bear its a 2006 Lt regular version with 125000 on it and I am the second owner it was a lease return
