Uplander 2005-2009
Platform: U-Body
Pulsating Brake problems
Old Jun 19, 2011 | 12:30 AM
ericmckinney's Avatar
Default Pulsating Brake problems
On my 2005, my brake light and ABS light have came on, this is now the 2nd time and have no clue what is wrong. The last time was the speed sensor attached to the hub assembly was broke off so I replaced both hub assembly with sensors attached to them because they had a little play in them. Lights went out after replacement, and now they are back on and not sure if the ABS module is going bad or what. I was wondering if the calibers might be locking up on me ever so often or just one of them locking up. Rotors are fine along with pads but that would not trigger the lights. What they car is actually doing is when driving and braking the car makes a loud pulsating rubbing noise and does not do it all the time and no it is not shimming because my rotors would need to be turned if that was the case but it only does it in spurts. Put new rotors and pads all around not too long ago. New hubs were put on last summer. Let me know, any help would be greatly appreciated.
Eric
Old Jun 19, 2011 | 3:16 AM
BigDawg's Avatar
Read these posts I'm sure I've read an older post about the same problem and having to buy bigger rotors to correct the problem!
SuperTexan
Jun 12, 2009 11:52 PM
astarfunkwaent
May 1, 2009 5:49 PM
Liberator
Apr 30, 2009 3:48 PM
SuperTexan
Sep 1, 2008 11:47 AM
grimani7
Apr 16, 2007 10:14 AM
