Uplander 2005-2009
Platform: U-Body
Shocks and Struts
Old Sep 30, 2010 | 1:59 PM
blackmillionaire2010's Avatar
Default Shocks and Struts
I am trying to do some research for my 2007 Uplander LS.
Can someone suggest some shocks and struts online that I can get my hands on for this vehicle ?
Thanks !
Old Sep 30, 2010 | 6:08 PM
Papa Bear's Avatar
https://chevroletforum.com/forum/uplander-31/new-shocks-35779/
The Monroe sensa-tracs on the rear really tightened up the van, no need to replace struts up front. How many miles on your 2007??
Old Sep 30, 2010 | 7:39 PM
the mechanic at NTB I needed struts, and that i had to get them from the dealer. I have 127,000 miles on my 2007 Uplander LS.
Old Sep 30, 2010 | 8:50 PM
Papa Bear's Avatar
Google will be your friend on this subject. Lots of parts out there, I suggest Monroe sensa-trac (not Monroe-matic). My $0.02
Old Oct 4, 2010 | 11:10 AM
timabrams's Avatar
Before loooking at struts ($$$) look at other parts of the front end. The sway bar links are infamous for being VERY weak from the factory, creating a front end sag and very poor "bump recovery". I'd recommend an upgrade there first (go with Moog, you'll be very happy).
I just cannot see a three year old vehicle, regardless of mileage, having front end suspension issues with the mcphearson struts yet. Doesn't make sense.
Old Oct 4, 2010 | 8:59 PM
Papa Bear's Avatar
Tim, the sway bar does not affect the ride height of the vehicle and you will notice the noise from a worn end link before you notice that it isn't doing it's job. Your poor "bump recovery" is the job of the shock/strut.
Mileage is the killer of shocks/struts and age is relatively immaterial. As mileage is accumulated, the shock/strut slowly looses it's ability to do it's job... it wears out. Often you don't realize that the suspension isn't performing as it used to until you replace the worn shocks/struts. They are maintenance items like tires and brakes, they wear out. New ones work .. well, like new.
127.000 miles is a lot of miles and the van would certainly work a lot better if the shocks/struts were replaced. My $0.02
07Chevyboy
Apr 1, 2015 9:03 PM
CMarkus
Feb 20, 2014 7:59 PM
davet
Jul 8, 2010 9:14 PM
Charlie3355
Jan 23, 2008 2:10 AM
Rocco
Apr 25, 2007 3:05 PM
