Uplander 2005-2009
Platform: U-Body
Slow coolant leak
Old Oct 26, 2015 | 10:35 AM
Shawn Mahoney's Avatar
Default Slow coolant leak
I am working on a 2005 Uplander with 3.5 engine. It is loosing coolant slowly, but I cannot find where. There are tiny bubbles that appear at radiator cap opening. The bubbles do not seem to change with RPM.
Question:
- what are some common places to look for a leak?
- what all could cause the tiny bubbles? They are slow, but steady.
Thanks to all who reply.
Old Oct 26, 2015 | 3:50 PM
Papa Bear's Avatar
Have a mechanic pressure test the system.
Old Oct 26, 2015 | 8:38 PM
U.Nanimous's Avatar
'05 Venture shouldn't be much different here. Bleeder vavle (brass screw in a plastic pipe). Top of the motor, passenger side and toward the front. Look at part #7.
How many miles? Overheating? Any other issues?
If you can't find it...+1 to Papa Bear's idea.
Old Dec 3, 2015 | 8:05 PM
mr_mahoney's Avatar
I pressure checked the system and saw wetness in the back corner (near firewall) where the timing cover and oil pan meet. I also saw some near back corner of head where it meets the block. I had a garage check it today they think it is the timing cover gaskets.
$910 for the parts and labor. I am going to get a second opinion.
Old Dec 3, 2015 | 8:34 PM
mr_mahoney's Avatar
Default uplander leak area
I degreased the engine and pressure checked. The picture below shows same leak areas, but with the tester removed, radiator cap back on and engine running. The coolant was visibly seeping where head met block but in pic it looks dry due to engine heat.
2005 uplander - 3.5 (coolant leak)
Old Dec 3, 2015 | 9:11 PM
the coolant cross over pipe gaskets are leaking. timing covers do not leak coolant.
4hr job at a shop.
Old Dec 3, 2015 | 9:13 PM
Papa Bear's Avatar
Have you added some Bars Leaks to the radiator?
I would start with that.
Old Dec 4, 2015 | 11:43 PM
cleveland63b's Avatar
fix it right, I would never recommend adding any "stop leak" its only a temporary fix at best and likely to cause other problems laterl
