Uplander 2005-2009
Platform: U-Body
torque tube clunk
Old Jul 12, 2015 | 3:17 PM
needanewhandle's Avatar
Default torque tube clunk
06 uplander. It clunks going into reverse or forward, right where the driveshaft goes into the "torque tube", whatever that is. Anyone else ever have this issue?
Thanks in advance.
Old Jul 22, 2015 | 11:41 AM
allenford's Avatar
Same here, once you back up and moving forward, apply a brake and you can hear a clunk.
Old Oct 20, 2015 | 9:00 PM
chevy55's Avatar
check rear mounts that hold the rear driveaxle to the rear frame.had the same issue,was the two rubber mounts that secures the drive axle unit to the rear frame.mine were both rotten.replaced them and the clunking stopped.hope this helps you out.
Old Nov 1, 2015 | 12:01 PM
march2008's Avatar
Finally got rid of the clunk. AWD wasn't working, changed the differential shut-off valve and the oil. AWD works again and clunk is gone.
DeHartShadow
Jan 31, 2009 6:53 PM
pnorris500
Jun 28, 2008 9:37 AM
stss95
Mar 30, 2008 11:45 PM
310sin24
Aug 14, 2007 10:24 AM
perlgoodies
May 21, 2007 10:46 PM
