uplander 2007 iac location
How many miles on the van? Is the CEL on?
Have you cleaned the throttle-body?
Are the spark plugs and wires original?
Are there any codes stored?
Does it idle rough in gear and in neutral?
Thanks for the info, Tech2...I already tried cleaning the TPS, but it still the same...anyhow.. I have a check engine light. I'll give an update as soon as i get an obd2 reader...
Papa Bear,
The van got 160K+ already...Yes the CEL is on..
The spark wires and pugs are replaced already... the TPS was cleaned...and still rough idling.If I press the pedal to the floor while I turn on the ignition key, there is ignition but will not continue when you release the pedal. But when no foot on the pedal and ignition is started it will continue and but it's idling rough.
thanks,
thanks,
I'm saying clean the throttle body - not the TPS
Like this https://www.youtube.com/watch?v=zUV4nXc-pXU
