Uplander 2005-2009
Platform: U-Body
Uplander - Lamp Control Modual removal
Old Oct 21, 2010 | 10:28 PM
JoeCB's Avatar
Default Uplander - Lamp Control Modual removal
Hi, I believe that I've tracked down the source of my electrical problems to a bad Instrument panel illumination dimmer modual. How do you remove that modual from the panel? is it just on clips? pry out??
For the benefit of others here are the symptoms... Blown #17 body fuse (back-up lights/ back -up alarm/and CHMSL also lost the instrument panel back illumination. All this is fed thru fuse #17. I believe that I have tracked the problem down to a short in the dimmer switch. Now I just have to remove it without damaging the instrument panel facing.
Thanks
Joe B
Old Oct 22, 2010 | 4:57 PM
JoeCB's Avatar
Thumbs up Lamp control modual removal - how to
OK, guys... I figured it out. So for the benefit of others.... everything pops off with spring clips. First pop off the silver trim strip below the light modual, use a puddy knife. Next pop off the light mod, one clip at the lower edge... it all comes free including the vent grill.
Joe B
Old Jun 30, 2013 | 1:10 PM
nhcamper's Avatar
I have a similar problem my instrument panel lights are fine but I have back up light or interior dome lamp,my mecanic is saying something about a body conttrol modual is this the same thing? my local deal quoted 200.00 for the part and my mechanic is saying that the modual needs to be programed to the truck?
janne.buckard@telia.com
Uplander
Oct 20, 2015 8:57 PM
robert99
Uplander
Aug 10, 2013 9:34 PM
voodoo91870
Sep 24, 2012 2:12 PM
DAVID5300
Astro
Sep 23, 2012 6:07 PM
Ryan Hepler
Feb 20, 2012 7:28 AM
