Uplander 2005-2009
Platform: U-Body
Vibration in Steering Wheel
Old Jan 18, 2021 | 6:06 PM
Martin Campos-Davis's Avatar
Default Vibration in Steering Wheel
2006 Pontiac Montana SV6 AWD
I have a vibration in the steering wheel. Wheel bearing recently changed. No play detected when shaking the wheel. CV axles don't appear bad - no torn boots and no clacking noises. Took it to the tire store and they balanced my studded winter tires, definitely felt better after that. Took it to an ASE certified mechanic to look at the suspension. Said my axles were fine front and back as well as the tie rods. They indicated it is one of the bearings in the drive line, but since the drive line (shaft) is a sealed unit and only sold as an assy, the mechanic contacted a driveline specialty shop but quote there was over 600.00 just for the part.
Question: Do you think it's worth to remove the driveline - go 2wd for awhile - and try to dissemble it myself? or is there any other potential culprit that could cause a vibration? Powersteering rack?
Attached is a view of driveshaft closest to the motor - Does that look normal? I can poke my finger in there - should that be sealed?
Vehicle has 173K miles
Thanks
RickR90s
Dec 21, 2020 7:44 AM
Southern Comfort
2007 - 2013 (GMT900)
Sep 25, 2019 4:23 PM
johnvip
Dec 11, 2014 11:59 AM
RitualJman
Feb 13, 2012 1:17 PM
mobilemodding
Dec 15, 2008 4:06 PM
