Uplander 2005-2009
Platform: U-Body
Wheel Hub Bolt Torque Specs.
Old Jun 2, 2017 | 10:04 PM
Patriot's Avatar
Default Wheel Hub Bolt Torque Specs.
Hello Guys, Does anyone know the wheel hub bolts torque specs for the front of chevy uplander ? It is minivan not extended and FWD only. I know the new bolts has a spec of 96 lb ft. what if im going to use the old bolt? Thanks in advance..
Old Jun 3, 2017 | 12:22 AM
the bolts are one time use as per the factory service manual. if you must reused them...make sure the bolts are not stretched, apply blue loctite and torque to factory spec for a new bolt.
