03 Venture headlight problem
Yesterday I discovered that my low beam headlights were not working. Everything else is fine--high beams, parking lights, instrument panel, etc... The manufacturer's book shows 2 separate fuses for the rt and left low beam headlights, but I don't even see them where it shows. (However, it does say "export only" beside them, which I am not sure what that means!) It also talks about a fuse behind the instrument panel that can blow if overloaded. I did have a Garmin plugged in, but didn't think that would cause it. It just seems odd that they would both quit at the same time, so I wanted to check with someone before I go buy 2 new headlights. Any ideas??
Thanks!!
Thanks!!
Its possible that they did quit at the same time.
Export only would mean Canadian, European, and Brazilian versions of the vehicle.
I would check the headlight relay as one of the possible causes. Swap it out with your horn relay to test the functionality.
garyv990
February 11th, 2015 9:52 PM
