Venture 1997-2005
Platform: U-Body
04 Venture Dome light won't shut off
Old Jan 3, 2020 | 7:49 PM
Krispin Gord's Avatar
Default 04 Venture Dome light won't shut off
Hello all,
The dome light on my Venture will not turn off as if the door was open, but the door ajar light does not come on the dash unless I open the door.
The key chime also sounds when I shut off the engine, but with the door closed, until I remove it from the ignition.
I appreciate any help you can offer
Old Jan 4, 2020 | 7:42 AM
There is a switch that manually turns on the dome light either at the light itself or on the dash. This may be in the on position or it may be faulty.
Old Jan 4, 2020 | 10:27 AM
Yes, but that wouldn't affect the key chime.
Old Jan 4, 2020 | 11:45 AM
Check the drivers side door switch.
Old Jan 4, 2020 | 12:14 PM
Where is that located? Also, it seems to be working fine as the door ajar light on the dash turns on as it should.
Old Jan 10, 2020 | 11:37 AM
I guess not many venture experts here
matthew74
Jan 26, 2019 9:48 AM
Scott81501
Jan 22, 2017 7:06 PM
kkosism
Dec 6, 2012 11:47 AM
davbell22602
Dec 5, 2009 5:33 AM
ukrkoz
Sep 21, 2009 12:43 PM
