Venture 1997-2005
Platform: U-Body
1999 Ventrue Alternator Changed?
Old Jan 2, 2015 | 10:22 AM
b.wedmore@comcast.net's Avatar
Default 1999 Ventrue Alternator Changed?
I have a 99 Venture that I just changed the alternator on (had a test tell me it was bad)tested new one before I put it in, the batt light is still on and it is not charging? I am at my witts end, anyone have any idea which way to go and what to test? I did switch the relays to make sure that was not the issue.
I really do not know where to go from here.
Thanks for any help
Old Jan 2, 2015 | 10:45 AM
Default I forgot the Batt light
I forgot the Batt light comes on and goes off and then comes on and stays on?
Old Jan 2, 2015 | 11:09 AM
Check all the wires and cables to the alternator and to the battery. Check them at both ends for looseness and corrosion.
Old Jul 11, 2015 | 8:28 AM
redroc501's Avatar
Default charging issues
Im having the same issues with my 2000 xhevy venture. Went through 3 different alternators, none are charging and batt light stays on and batt drains.
caj600ho
Aug 26, 2008 11:44 AM
larry_chip
Apr 24, 2007 11:46 AM
Trick Concepts
Mar 19, 2007 8:28 PM
ezdno
Mar 7, 2007 8:21 PM
marge simpson
Dec 7, 2006 1:18 PM
