Venture 1997-2005
Platform: U-Body
2004 Chevy Venture Passenger Window Goes Down but NOT up
Old Jan 20, 2012 | 10:03 PM
Soxman's Avatar
Default 2004 Chevy Venture Passenger Window Goes Down but NOT up
The passenger side window goes down but not up - when using either the switch on the passenger door or the driver side door. I have removed the door panel and troublshooted a bit by switching the wires which worked to have the window go back up. I think that tells me the motor works. What would cause only one direction not to work? Any advice how to fix?
Old Jan 20, 2012 | 10:42 PM
EinST's Avatar
Welcome to the forum. The driver window switch is probably bad. Pull the electrical connector off the motor and then check both wires for continuity to ground. What provides this ground is the driver window switch. When you work the switch, you're switching in the power over one wire which won't do anything if the other wire isn't grounded.
Old Jan 21, 2012 | 7:04 AM
Soxman's Avatar
Thanks EinSt. So you think it would be the driver side switch even though it is the passenger side window that won;t go up? The driver side window works.
Old Jan 21, 2012 | 8:15 AM
EinST's Avatar
If you could work the window from the driver window switch in one direction, that'd prove the wiring is good all the way. I think you'll find that one of the wires that goes to the motor isn't grounded at rest. If so, it has to be driver window switch.
Old Jan 21, 2012 | 11:18 AM
Soxman's Avatar
Ok, thanks again. I just ordered a new driver side switch and will keep my fingers crossed that it will do the trick! I will let you know.
Old Jan 26, 2012 | 9:00 PM
Soxman's Avatar
Hey EinST, you are a miracle worker! $16.97 for a new driver side switch on Ebay, installed myself and passenger window working again! Unreal. Dealer wanted over $80 for the part plus I would guess about $200 to install - that is if they even diagnosed it properly and did not repair unnecessary parts. THANKS AGAIN!
Old Jan 26, 2012 | 9:54 PM
EinST's Avatar
Congrats. It's really priceless when you fix it right and save money in the process. Thanks for the update.
Old Feb 26, 2012 | 11:36 AM
Tony S45's Avatar
I have replaced a couple of the window switches in our 2003 Venture. Very common problem.
Another common problem that can be fixed inexpensively is a sticky window. Recently our drivers side window would go down in a hurry but go up about half way and then just creep & creep up inch by inch. Sprayed auto silicone down both window rails and now the window shoots up & down without any hesitation.
Old Mar 6, 2012 | 2:36 PM
Merture's Avatar
I also have been dealing with that problem .
Cant tell you how many times I have pulled that door panel to check or align .
Even once replaced a motor . I'm sick and tired of spraying down the channel .
So soon I'm going to just replace the window weatherstrip /channel.
As I see no other reason for this flaw
Old Mar 7, 2012 | 6:22 AM
Tony S45's Avatar
Merture:
Please let we Forum members know the approx cost and difficulty of replacing the window weatherstrip.
Thanks.
Tony S45
