Venture 1997-2005
Platform: U-Body
98 Venture cooling fans won't shut off
Old Apr 5, 2010 | 4:01 PM
vacuumbed's Avatar
Unhappy 98 Venture cooling fans won't shut off
Hi everyone,
I just acquired a 98 Venture with a interesting cooling fan issue. I say this because the majority of complaints of these vans is that the cooling fans don't come on until the engine is pretty hot. Not this one.
I suspect someone has modified the cooling fan circuit, but I'm not sure yet. Here are the symptoms and facts.
Both cooling fans run at full speed when the key is on the "off" or "on" position. In the "lock" or "acc" both the fans are off.
SES light is on with error code P1651. Engine coolant blower motor relay 1 circuit malfunction.
I tested relay 1 and it is good.
There is no evidence of tampering in the relay center, including the lower wiring section of the relay center.
Is it true that the PCM controls the cooling fans in the 1998 model year? If so, I wonder if the PCM is defective.
Thanks in advance.
63c10guy
Nov 20, 2011 7:27 PM
ads_210
Dec 11, 2008 6:43 PM
Silverado02
Dec 8, 2008 12:28 PM
SilveradoLS02
Aug 12, 2008 8:45 PM
