abs question
abs question
hello to all new to the site , have 2004 Chevy venture , need to replace the rear wheel bearing and hub mine has abs ,part that came has no abs sensor on it . is it okey to put on and not hook up abs till i can get the right one? thanks to all that answer.
hi , if you do that your abs light will come on the dash board , and you'll not have the abs system working on your car , you can live with no abs if you'd like to but its dangerous some times man specially when wet
jerryz71
April 11th, 2010 6:09 PM
