Venture 1997-2005
Platform: U-Body
After market radio for 2004 Venture
Old Apr 25, 2015 | 8:26 AM
rfp9898's Avatar
Talking After market radio for 2004 Venture
I bought a 2004 Chevy Venture that did not have a radio in it. I thought it would be easy to install a After Market radio in it. Power and all functions work except there is no audio output. I ohmed out all the speaker wires thinking there was a ground issue. They all checked out. I then hooked a tone generator to each speaker wires to make sure they weren't blown. Checked out good. Any help would be appreciated.
Old Apr 25, 2015 | 8:40 AM
are all the speakers the same ohm rating? if they are not, the aftermarket radio will think a short is present. disconnect either both front or both rear speakers and see if you get sound.
does the factory system have an amp?
Old Apr 25, 2015 | 9:56 AM
rfp9898's Avatar
Yes. I checked. They all read the same.Not sure on power amp.Can't find any info on it.I thought maybe that was the problem and went looking for a fuse. No luck.
Old Apr 25, 2015 | 4:22 PM
rfp9898's Avatar
Found the problem. After moving some wires around,I found another Blue wire in the bundle.Ohmed out the same as the rest, nevertheless I decided to try it. Violia. It worked. Thanks for the tip.
mrjimmys2000impala
Jul 19, 2015 9:04 AM
Sebx559
Mar 6, 2014 6:06 PM
arkrider410
Sep 9, 2012 6:21 AM
djm1951
Camaro
Aug 13, 2010 7:06 PM
