Venture 1997-2005
Platform: U-Body
coolant fans relay wiring
Old Jul 19, 2024 | 3:55 PM
venture05's Avatar
Default coolant fans relay wiring
hello
im tired of having my coolant fans turn on at 230 or so which is pcm controlled.. so im wiring a relay with a capillary so i can adjust the temps i want to have...
i figured out grey n white wires are what i need to connect for high speed but..
when i connect white wire it turns right fan to highspeed driver side fan doesn't turn on unless i ground the grey wire
so question is how would i wire up 5 pin or 4 pin relay so it grounds grey wire when the capillary says its time to turn on
wiring for the capillary
  • C Terminal = 12v Feed
  • No2 Terminal= Power out to the fan
  • (the switch is earthed through the fan)
  • No1 Terminal= Leave blank, this is not required for this application
  • You can also wire a relay in if you wish, but this is not a requirement.
Capillary Thermostat link Capillary Thermostat link
any help would be great wiring relays aren't my thing lol
Old Jan 20, 2026 | 6:30 PM
FL_Apache's Avatar
I had a fan issue with my 05 Venture and was never able to figure out why the fans were getting no power. I installed a heavy duty relay and have both fans running fulltime when the engine is running. Problem solved.
markfothebeast
Oct 17, 2024 10:23 PM
Peanutbuter4040
Sonic (Aveo)
Jan 1, 2024 5:26 PM
David Shutovich
Cruze
Nov 29, 2018 11:29 AM
Matthew Brown
Apr 30, 2018 8:04 AM
blownZ28
Camaro
May 12, 2008 7:17 AM
