Venture 1997-2005
Platform: U-Body
lack of acceleration
Old Oct 4, 2023 | 4:01 AM
Tysman2002's Avatar
Default Sputtering
Hey so I have a 04 venture and just a couple of days ago my van started sputtering it’s usually only when press the gas
I had to fix my exhaust and have it up by 2 vice scrips but maybe one of them have came loose a little bit so it’s making it shift weirdly
Old Oct 4, 2023 | 7:32 PM
Photon440's Avatar
What sort of "sputtering" symptoms? When you say "press the gas" do you mean off idle from a stop, or it runs okay while cruising but sputters when trying to accelerate some more?
Is there a CEL showing? Some possibilities, based on my own Venture included low fuel pressure (needing fuel pump replacement) and a bad sensor behind the front damper.
Old Oct 6, 2023 | 11:27 PM
Tysman2002's Avatar
thanks for the reply
it happens when i go to accelerate from a stop and also happens when i try to accelerate some more, yes their has been a CEL showing but haven't had them scanned plan on doing that tommorow
Old Oct 7, 2023 | 1:18 AM
Photon440's Avatar
Just in case some ideas pop out of it, this is the thread where I had my original problems.
https://chevroletforum.com/forum/ven...ration-100802/
Old Oct 8, 2023 | 10:41 PM
Tysman2002's Avatar
Default lack of acceleration
so after my last thread a lot more has happened, the van started bogging/locking up when i go to accelerate, i replaced calipers, and the 02 sensor. neither worked
the caliper helped a little. it doesn't completely bog/lock up just runs high rpm when it shouldn't be
Old Oct 8, 2023 | 10:56 PM
did you get it scanned?
when you do, look up the codes on obd-codes.com and follow the troubleshooting there.
Old Oct 14, 2023 | 4:38 AM
Tysman2002's Avatar
same thing im dealing with
Old Oct 14, 2023 | 12:30 PM
Photon440's Avatar
When you mention that it locks up, you're meaning that the brakes apply when you hit the gas? Or is it possible that the transmission is causing problems that give similar results?
Old Oct 25, 2023 | 10:01 PM
Tysman2002's Avatar
UPDATE
$300+ later I am able to say the problem was a clogged/old transmission filter
Old Oct 25, 2023 | 11:44 PM
How many miles on it?
