Venture 1997-2005
Platform: U-Body
My cup holder is stupid and I need a workaround
Old May 10, 2025 | 11:48 PM
VENTURECLUB's Avatar
Default My cup holder is stupid and I need a workaround
I don’t believe that when Chevrolet made the venture, they designed a cup holder that pull out and then down if you put too much force on them. Am I right about that, because my cupholder would come out but if I put something in there that was heavy. The whole cupholder would just slant downward enough to spill some of my drink onto the floor.
I removed it because the auxiliary outlet is jiggling and blowing fuses every time I plug something in. Obviously, you have to remove that first. So I have two requests. The first is what do I do about a cupholder that doesn’t fall down like that are there aftermarket ones?
Secondly , I’d like to share with you my experience of frustration as to why this car didn’t come with a console in between the two front seats or anything that’s within an arms reach of the driver for storage. If I want something out of the glove box, good luck, pal I’ll probably get into an accident because whatever I need, it’s always 3 inches or less out of reach.
so I’m looking for a hack to get around the storage issues, the cupholder, and also this is going to be included in a different thread that I create a light bar that has I don’t know more than 10 lm shining outward through the oxidize plastic coverings over the front headlight. OK, I’ve ranted enough. Any help is appreciated, thanks
Old May 13, 2025 | 11:31 AM
The cupholder may have a cracked slide or some damage to the mechanism. Your model may not have come with a console. Check the junk yards and you may find a console for your model or one that is close enough to fit. They do make universal consoles. Amazon has them with pictures, so myou can pick one.
Old May 13, 2025 | 10:02 PM
Photon440's Avatar
I have not seen any of these vans (Chevy Venture, Pontiac Montana, Oldsmobile Silhouette) having a factory center console. Not floor mounted at any rate, I know you're not interested in a ceiling console. Not even the sporty Silhouette OSV (Oldsmobile Special Vehicle) had one. I asked around here earlier but got no replies.
As for cloudy headlights, new ones are just an amazon click away. First thing I did for my vans.
edvard
1988 - 1998 (GMT400)
Jan 20, 2024 8:44 PM
TexasRoadrunner
May 2, 2020 8:43 AM
darby dawg
Aug 27, 2012 9:51 AM
Montana Vigilante
May 6, 2009 7:51 PM
omnicube
Oct 8, 2007 12:51 AM
