Venture 1997-2005
Platform: U-Body
SIR(Airbag) problems
Old Aug 9, 2014 | 6:25 AM
ebaman's Avatar
Default SIR(Airbag) problems
I have intermittent B0045 and B0040 errors.
This should translate to:
DTC B0040 LF/Driver Side Deployment Loop Resistance Low
DTC B0045 LF Side Deploy Loop Short to Ground/Voltage Out of Range
Anyone that has a clue where to start looking, and how to do it, I guess that sticking a DVM on the airbag connectors is not a good Idea.
Its an 2002/2003 Chevy Venture
Old Aug 10, 2014 | 2:34 AM
sergeimoskva's Avatar
Hi !
Code B0040 will set when the SDM detects the LF side impact module deployment loop resistance is less than 1.3 ohm for 500 milliseconds .
DTC B0045 will set when one of the following conditions occur:
... the SDM detects the voltage at LF side impact module high control is greater than 6 volts for 500 milliseconds .
... the SDM detects the voltage at LF side impact module high control is less than 2.4 volts and LF side impact module deployment loop resistance is less than 6 ohm for 500 milliseconds
If DTC B0040 is present, test for a short between the LF side impact module high and LF side impact low control circuits. If DTC B0045 is present, test for a short to ground or voltage in the LF side impact module high and LF side impact module low control circuits.
Most likely you have a problem side seat driver airbag. See wire break or short circuit
Old Aug 10, 2014 | 3:22 AM
ebaman's Avatar
Yeah, I know all that.
However, need to test the harnes, since I don't have the "Load Test Tool" specified in the workshop manual, question is that if a 2 Ohm resistor will do, as a replacement.
Old Aug 11, 2014 | 3:21 AM
Hi! You had this in mind ...
Old Aug 12, 2014 | 3:55 AM
ebaman's Avatar
Nope, Replace the "Inflatable Restraint Module" with a 2 Ohm resistor, and se if the error is still there.
robin93784
Jan 5, 2014 11:35 PM
09_Uplander
Apr 3, 2012 7:08 AM
Turbo79
Aug 27, 2010 12:34 PM
scout118
Oct 24, 2009 5:59 PM
Intruder
Sep 7, 2007 4:47 PM
