Venture 1997-2005
Platform: U-Body
View Poll Results: How to remedy
Linkage problem
0%
Clogged valve
0%
Band needs adjusting
0%
Possible other solutions
100.00%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
Venture Auto Transmission “Bangs”
Old May 15, 2021 | 11:45 AM
John21851's Avatar
Default Venture Auto Transmission “Bangs”
Can’t find this particular problem in any of the threads. 2005 Chevy Ventura minivan. Transmission “slams Hard”into 2nd gear. No problems shifting into any other gear, just from first into second.. (unless I manually shift the automatic transmission from first into second). If there was a problem with the pressure valve (solenoid) wouldn’t that affect all the gears?
Old May 27, 2021 | 7:03 PM
Photon440's Avatar
I don't think it's a particularly uncommon problem. The 4T65-E transmission, whether in your minivan, or a Buick Century or Pontiac Grand Prix is known for this.
If you have an OBDII tester, see if you can find a trouble code, such as P1811. You didn't say how many miles are on the transmission, but it could simply be that second gear is wearing out. If this is the case, then is will start shifting slower. But the transmission 'brain' sees this as a problem and so puts in full line pressure, causing an abrupt shift. You could live with it, or rebuild the transmission, or for much less cost put in a shift kit (such as https://zzperformance.com/products/4t65e-shift-kit ) which will speed up the shifts so that the computer doesn't react to it.
joey.wallace88
Avalanche
Apr 2, 2018 2:12 PM
natureboy
Jul 11, 2014 2:32 PM
Trainingdragon
Mar 18, 2013 8:12 PM
Tegnus
Nov 10, 2012 10:57 AM
beech2014
Sep 18, 2012 10:34 PM
