Venture 1997-2005
Platform: U-Body
Venture Engine Idle
Old Jun 6, 2007 | 2:21 PM
C3banjo's Avatar
Default Venture Engine Idle
I'm reposting this from the general technical forum. This is year two that my '01 Venture van's engine is racing at idle and during regular driving.It seems to occur with summer temps (85-90+). When driving it is like the cruise control is on. The accelerator doesn't "kick-down" the idle. Turning vehicleoff then on doesreset the idlebut it jumps back up after acceleration. Problem comes and goes randomly.My mechanic put it on the computer and everything seems ok. Anyexperience or ideas? thx
Old Sep 18, 2007 | 7:54 AM
C3banjo's Avatar
Default RE: Venture Engine Idle
Problem occurence is less frequent I'm guessingdue to cooler Sept.temperatures, however, problemoccured regularlyin August.Since then I've had to replace the serp belt and the small radiator hose on top of motor. I'm assuming that the increased heat due to motor racing is partially responsible. I've read that this could be due to a problem with the Idle Airspeed Controller. Looking for input. thx
Old Sep 23, 2007 | 12:00 AM
goingmyway's Avatar
We had some weird idle problems caused by a vacumm leak. The PCV line had a section that was made of some hard plastic rather then flexible hose. This hard plastic section had a crack. We didn't however have the overheating trouble.
capezig
Mar 18, 2015 5:14 PM
Melody Smith Arquillo
Dec 3, 2012 12:48 PM
bwiles001
May 14, 2012 4:14 PM
Thermool
Jun 20, 2009 6:41 PM
linxinx
Apr 1, 2008 9:42 AM
