1996 1500 No Spark,,,, I need help
hey yalll
I have a 1996 chevy 1500 5.7 V8 4x4 that i am not getting spark on,
I have discovered that i have no power to the ECM, ICM, and one other fuse in the fuse box under the hood, The rest of the fuses have power.
We pulled it apart and all the connections are clean and tight and there are no burn marks or exposed wires.
I had to move the truck to my new place so we put a jumper from the AUX power stud on the fues box to the ICM fuse and it ran fine,
so my question is would that be the Ignition harness in the steering column that is causing the loss of power to the row of fuses.
Last edited by chevyrocks43; Mar 11, 2018 at 10:16 PM. Reason: discovered the problem
