Brake question
Brake question
Just had to replace rotors calipers and pads on the rear of my 2003 1500 z71. I now have a service brakes light on. I have bled the brakes and it looks full under the hood. How do I reset this warning?
You'll probably have to have that reset with a abs capable scan tool is this intermeittent? It could be an issue with the EBCM ground (electronic brake control module).
if its the red brake warning light...did the master go dry? Pretty sure they use a reed switch in the master reservoir for the low fluid warning. If you unplug the connector does the warning light go out?
yeah, cause the codes will be chassis dtc or body dtc not powertrain codes. code readers can't read anything but powertrain codes.
did you try unplugging the brake fluid level connector on the master cylinder like i suggested.
